Using Xpage Control as an Embedded View Filter Key
I’ve embedded a view into an xpage - works great. What I want to do now is filter the view results using a Key. I’d like the key to be the text string in my xpage control ‘label1’. I can’t get this to work. If I hard-code in a value like ‘Abel’, the filtering works, this is the code:
<xp:dominoView var=“view2” viewName=“rolebyres”
keys="#{javascript:'Abel'}">
How do I substitute the text string in my control ‘label1’ into this code? Any suggestions please. JV
Subject: Is the Function currentDocument.getValue() appropriate?
Reviewing the literature, perhaps using the server side 'CurrentDocument.fetValue() function might be the ticket for this, using the document field name ‘ComputerName’ as the key:
					keys="#{javascript:currentDocument.getValue(ComputerName)}">
</xp:dominoView>
This code generates an error:
Required property “viewName” for xp:dominoView is not present.
But am I at least on the correct path? Any comments appreciated. JV
Subject: Use getComponent(“foo”).getValue()
You are very close. This is what you need to use:
<xp:dominoView
var="view2"
databaseName="foo.nsf"
viewName="rolebyres">
<xp:this.categoryFilter><![CDATA[#{javascript:getComponent("label1").getValue()}]]></xp:this.categoryFilter>
</xp:dominoView>
Of course you don’t need to use a label (and maybe shouldn’t really). You can use a combobox or editable field, or value from a selected document. XPages gives a lot of flexibility.
hth --Graham
