HiSince its not so easy using Wsad to develop java-code to my Domino-application I would like to hear which WSAd-Books there are on the market that give a good indsight/konowedge to getting start using WSAd.
Specially for people with Domino-background.
Subject: TLCC has a few tips on using WSAD with Domino plus courses on WSAD
See WebSphere training courses - TLCC's distance learning training courses are the ideal way to learn how to develop WebSphere applications with WebSphere Studio for info. on the courses.
For the tips go to:
Domino Designer 6 supports using Java for Domino agents. The Domino Designer client can be used to create, edit and compile Java agents. However, there is no debugger and the editor does not list the available methods as when coding LotusScript...
Domino Designer 6 supports using Java for Domino agents. The Domino Designer client can be used to create, edit and compile Java agents. However, there is no Java debugger when coding Java agents in Domino Designer.
WebSphere Studio has an...
Howard
Subject: RE: TLCC has a few tips on using WSAD with Domino plus courses on WSAD
Hi thanks for the links, I already know them.
Can you recommend any good Book that I can use for the Purpose.
