Using web calender picker
Could any please help me on this issue?
I have a web document with a date field, and I need to get this date and put it in anothers date fields changing the values automatically. Ex: If I have 02/10/2006 (using web calender picker) on the web field, I need 02/11/2006, 02/12/2006, 02/13/2006… on the destination fields.
Thanks in advance,
Bia
Subject: using web calender picker
Two options:1. If you need to display those destination fields as document is being edited, use JS to manipulate and pass the values (the dates are simply text on the web).
  1. If there is no need to display these at the front end, use computed fields with @Adjust to create the dates needed.
HTH,
Simeon
Subject: RE: using web calender picker
Hi Simeon,Thank you. Those tips were very helpful. I will be the option 1. Thanks again.
