Using $$viewbody field in web
Hi,I am new to web applications.i am trying to use the $$viewbody field but i seem to be missing
something…the output is not clear.also i cant uderstand what is the difference between $$viewbody
and embedded view since both work well on web.
if somebody can give me a step-by-step description on how to use it,i would be very grateful.
Thanks,
Rekha
Subject: Using $$viewbody field in web
hi i am amarThis was not very diffence only
1st difference-> one can use embedded view and one use $$viewbody,all are work in same but in a form the embedded view take large sapace where as $$viewbody take small sapce that is one field and remain sapce of form u degin as u wish.
2nd difference-> $$viewbody runs only web not in notes.
    Step of creating $$viewbody
step-1->First u create form and take two field name and adress and save it
step-2->Then create view for this form and save it(ex-vemp)
step-3->create another form and take one field name as $$viewbody and give view name “vemp” as deafult value
step-4 then run this form in net.
Amar
$$viewbody was the only way to add embedded views back in notes 4.5 from what I recall. It is still supported for backwards compatability. Yuo can use either method, although you obviouslly don’t have any options when using the $$viewbody field.
Subject: You’re correct; it was R4.6 when embedded views were added, thereby obsolescing $$viewbody
except, of course for $$searchtemplate forms, where the damn ancient things are still the only way to get your view.
