Using two or more smartcard with smartcard enabled ID
Hello,
I want to know if it’s possible to use two or more smartcards with the smartcard-enabled ID ?
I saw that when I enable smartcard support for an ID, Notes will generate a CKO_DATA object on the card. This object is composed of the following fields :
Token, Private, Modifiable : true
Application : Lotus Notes
Label : Password : XXXXXXXXX (16 chars)
Value : Hex data
What is the meaning of the Label field ? Is the password string is the real password of the ID ? What is the meaning of the Value field ?
Is it possible to copy the content of this CKO_DATA object to another card ?
Also, how can I programmatically smartcard enable an ID ?
Thank you,
Anton.
Subject: Using two or more smartcard with smartcard enabled ID
When you smartcard-enable an ID file, information identifying the token is stored in the ID file. Notes will then prompt the user to enter the correct smartcard if a different token is in the reader.
You can use SECManipulateSC to programatically smartcard-enable an ID file. I’ve included some fairly sloppy pseudocode for SECManipulateSC below. As always, real code should check for errors and actually do something with return values. :slight_smile: SECManipulateSC is well documented in the C API Notes/Domino Reference; you should be able to find more useful details there.
Good luck,
dave
error = SECManipulateSC (SC_manip_GetVersion,
                         NULLSCMCTX,
			 NULL,
			 &Version,
			 NULL);
/* Initialize the PKCS#11 context.
SCMCTX Context = NULLSCMCTX;
error = SECManipulateSC (SC_manip_InitializeContext,
			&Context,
			NULL, NULL, NULL);
/* Unlock the smartcard
error = SECManipulateSC (SC_manip_EnterPIN,
			&Context,
			NULL,
			&dwPINLen,
			PIN);
/* Note – SC_manip_EnterPIN will use an external authentication path if it exists. If the token doesn’t support a protected authentcation path, SC_manip_EnterPIN will use the supplied PIN if one exists or generate a prompt if a NULL or zero-length PIN was used. */
/* Set up the ID file
error = SECManipulateSC (SC_manip_EnterIDFile,
			&Context,
			 NULL,
			&dwIDLen,
			IDPath);
/* Smartcard-enable the ID file
error = SECManipulateSC (SC_manip_SCEnableID,
			&Context,
			NULL,
                       &dwPasswordLen,
                       pPassword);
/* Clean up
SECManipulateSC (SC_manip_TerminateContext,
	   &Context,
             NULL, NULL, NULL);
Subject: RE: Using two or more smartcard with smartcard enabled ID
Thank you Dave,
But if a user have two smart cards (one for backup), the only way to enable the second card is to pass through recovery process (to disable the first one)? Right ?
I’ve done different tests and remarked that if I have the extension manager that is registered for EM_GETPASSWORD, the method is always called even if I use smart card enabled ID. What’s the point here ?
Thanks,
Anton.
UPDATE: EM_GETPASSWORD support for smartcard-enabled IDs was added to 6.0.4/6.5.1
Correct.
That’s a bug. The extension manager cannot unlock an ID file that is protected by a smartcard. I’m looking into the possibility of adding support for that into a future release.
dave
Subject: EM_GETPASSWORD with smartcard-protected ID files
You’ll be able to use EM_GETPASSWORD extension manager callouts to unlock smartcard-protected IDs by passing the smartcard’s PIN in through the extension manager in 6.0.4 and 6.5.1.
dave
