Using Sum for multi-value fields
I have multi-value Name field and numberic field. Numberic fields calculates Name field and give total of people. Name field is separated by comma and numberic field has below formula.
FIELD People:=People;
@Command([EditDocument];“1”);
@SetField(“People”;@Sum(@TextToNumber(Whom)));
@PostedCommand([FileSave]);
@PostedCommand([FileCloseWindow])
I get @Error message.
Please advise
thanks
amp
Subject: Using Sum for multi-value fields
If you just want the number of names in the Name field, try using @Elements instead.
Hope the helps.
Subject: RE: Using Sum for multi-value fields
thanks it works fine nowamp
