I’m attempting to generate an email with a html link in it. I want to open the doc by using the unid, but just not having any luck - I’m getting the desired text and everything works - just the doclink is broken…
Call stream.WriteText(|<a href=“http://server/folder/DB.nsf” + unid + “?OpenDocument”>Link Text|)
I’ve got a handle on the unid and the actual document - but how do I use either of these variables using WriteText ??
Subject: Using Stream.WriteText with a variable
The URL has to look like:
http://server/folder/db.nsf/viewname/unid
The ?OpenDocument is optional (?Open is the default server command), but the slashes and the viewname are not.
Subject: RE: Using Stream.WriteText with a variable
Hi Stan - so we meet again! Thanks for your ever presence to help us rookies out!
I realized after I posted that I need a view name too, but my issue is getting the unid variable enclosed inside the quotes.
Call stream.WriteText(|Link Text|)
When I use this line of script, and click on the link generated, I only get as far as the view or the second enclosing quotes. How do I combine this to get the unid variable in there? When I use it trying to concatenate the unid - I get this in my URL - view/%20+%20unid
Ah, that’s because you’re using your delimiters wrong. A vertical bar is closed only by another vertical bar, curly brackets only by other curly brackets, and so on. What you want between the parentheses is this:
|<a href="http://server/folder/DB.nsf/view| + unid + |>Link Text|
The way you’ve got it now, your script is treating the "+ unid + " bit as a literal rather than as an expression.
M. thanks for your response!
Where do I close the href string? I don’t see the ending " in your example… Sorry for being so dense…!
My bad:
|Link Text|
Thanks again for your response M… I eventually figured it out after placing it just about everywhere in that sting…
