Using CSS for styling on web
Hi,I have made a simple CSS file for styling the buttons on my web form .
I have imported it into the database.Now i m unable to understand how to use it or how to call it so that it affects the buttons on my form.I tried writing the name of the Css file in Class option the HTML tab of the Button but thats not working.
I m new to Web development on Notes , so i’d appreciate any input in this matter.
Thanks a lot in advance
Subject: Using CSS for styling on web
KushiYou just need to insert resouces in to a page or form. Then the page or form wil start using the .css file.open the form or page, place cursor where you want to insert css file. Go to Create-> Insert Resources- insert resources select style sheet from the list and select the imported the stylesheet …as simple as that…hope this helps…wht other co member posted is used in R5 …not in R6… but you can also use that…if you want to.
Cheers
Sri.
Thanks Pawan and Venkat,
Both methods work great!!
Khushi
Hi Khushi, Create a Page write your css in this page.
Save the page---->
style_addressbook.css
Now Open the For where u want to use the css…
In Forms—>
HTML HEAD CONTENT EVENT---->
Write the code for calling the css page
It Will Work
Hope this will help u?
