User's Fullname help
Im trying to make a silent install of Notes for Citrix users. I have everything working except for the username it requires.
Our local username is as follows.
JFerraro ← windows logon
Username for Lotus Notes
Jeff Ferraro
I have a snippet of code and am wondering if anyone would be able to help me figure out how to successfully implement it into the notes.ini file in order to complete the install.
thanks.
JEff
Start Code
Sub PullUserFullname(strDomain,strUser)
Dim User
Set User = GetObject("WinNT://" & strDomain & "/" & strUser & ",user")
Response.write User.Fullname
End sub
Subject: User’s Fullname help
Edit: we use the following code and successfully pull the username that we are looking for. how, how do i get it to use this script in the notes.ini?
Start Code
option Explicit
dim strDomain
dim strUser
dim User
dim Objectpop
strDomain=“company_domain”
strUser=“tcitrix”
set Objectpop=createObject(“wscript.shell”)
Set User = GetObject(“WinNT://” & strDomain & “/” & strUser & “,user”)
Objectpop.popup "Name is: " &User.Fullname
