Hello,
I have a problem with view applets in $$ViewTemplate… forms.
Steps to Reproduce:
Design a Notes Database enabled for using web browsers.
Enable ‘Show selection margin’ in your views
Use ‘$$ViewTemplate…’ forms to display views on the web.
When opening the view in your browser, no selection margin is visible.
Workaround:
Deselect ‘Use views selection margin property’ in Embedded View properties (Info tab) in your ‘$$ViewTemplate…’ forms (see screenshot)
Select ‘Show selection margin’ in Embedded View properties (Disply tab) in your ‘$$ViewTemplate…’ forms (see screenshot)
Is this a bug? Or how is it possible without my workaround?
best regards
Marco
