Use View Dialog for Choices Problem
I have a form with several dialog list fields on it. This form was pasted form a database on my server into a replica of the same database on a client’s server. The fields use the “current database” and “use view dialog for choices.” When the drop down list is clicked, most of these fields give me the “Choose servers to search” dialog box. Even when I deleted the fields and recreated them this problem continued. There are no local replicas of that database on the workstation I am using. I also pasted a subform using some of the same views in the same database into the client’s database, and there was no problem there. What could be possible reasons that the fields do not know which server to search for the views? Thanks.
