USE or USELSX problem
Hi all.I have web agent
that uses execute command
like this
execute Use MyScriptLibrary MySub().
In MyScriptLibrary (options) i have the next statement
Use OtherScriptLibrary.
When I run my agent I receive the next error
“Error loading USE or USELSX module: OtherScriptLibrary”
What the problem ???
Thank you in advance
Subject: USE or USELSX problem
Check if there is no UI classes used in OtherScriptLibrary library.
Konrad
Subject: RE: USE or USELSX problem
Thank youthat was the problem :slight_smile:
Subject: Recompile All LotusScript
Hi Benzi,
Try using Tools-Recompile All LotusScript and then re-sign the database. This usually works for me when I see this error.
Regards
David
Subject: RE: Recompile All LotusScript
