URL does not open in web for no reason
Hello all,I am trying to open this url from a button in my web application
@URLOpen(“http://server/WebTravelReq.nsf/Travel_Request_Header_ID?OpenForm”)
but I get a blanck page ,I tried copying and pasing the url into the browser I got the same black page,although I tried to open the same page from a hot spot and it worked any ideas why is that
Reagards
Subject: URL does not open in web for no reason
Try replacing the spaces with %20 and see if it helps.
Subject: RE: URL does not open in web for no reason
I’m even lazier, and normally just put in plus signs (+) instead of %20’s. Remember spaces in URLs are “bad.” :slight_smile:
Actually, I tend to use plus signs as well, but I usually avoid spaces anyway I can.
