I have upgraded a Domino server from 7.03 to 8.5. The 7.03 Domino server was running on Windows server 2003, the 8.5 Domino server is 32 bit and is running on Windows 2008 server 64 bit.In a Notes application I have an Lotus Script agent which has to write records into a SQL database on a SQL server. On the Windows server where Domino is running I created a ODBC (system DSN) datasource to communicate with the SQL database.
The agent is scheduled to run on the server. with runtime security level 3.
On Windows 2003 with Domino 7.03 everything went fine.
Now the agent cannot create the ODBC connection
Dim con As New ODBCConnection 'Make ODBC Connection
If Not con.ConnectTo("prices","user","password") Then
Print "Could not connect to prijslijsten"
Exit Sub
I let things writing to a Notes Agent log and this says:
An Error LS:DO- ODBC could not complete the requested operation.( 720) has occurred on line 42 in ExportAgent
Line 42 is this line: If Not con.ConnectTo(“prices”,“user”,“password”) Then
When I run the agent not scheduled but On Event, Agent Menu Selection from the Notes database, the agent is running fine.
The ODBC Datasource should be ok for when I test the connection it is succesfull.
I am afraid that this has to do with the way Domino as service is running on Windows 2008 server.
Domino running as an application is not an option because my antivirus program will only work when Domino is running as a service.
Has anyone an idea how to solve this.
