Pls help some one.I need to change the color of a particular field say “STATUS” depending upon the value in the CURRENT STATUS field.i.e,if the CURRENT STATUS = “APPROVED” then the text in the STATUS Field should be Red in color and in case the status in the CURRENT STATUS = “REJECTED” then the font color of STATUS field need to be green.
I am using NotesRichTExtStyle but its not working.
Subject: URGENT PLS HELP :: How to change color of field depending on certain criteria
Hide your status field. Then add a programed table with two rows. In each row add a computed for display field set to display your status. Set each field to a diffrent color text. Set the table to display the rows based on the status value.
Subject: RE: URGENT PLS HELP :: How to change color of field depending on certain criteria
As far as I know, the Rich Text style can be used to append to a rich text field, add text in with those font settings etc and so on. It can’t be used to dynamically change the color of a text field…
That being said … I think urgent is in the eye of the beholder but isn’t it ‘against the rules’ to use it in here?
How in the world is the color of a font urgent? will someone die or be injured because of it? Forgive the cheekiness, but the urgent is not really needed:-).
