Urgent Help Reuired on LS Sorting and unique
Hi My requirements are to sort the data which i am taking in an array and the remove the duplicate entries from the array and then print it in the entries,everything is fine but i am not able to think for sorting and unique.I am apsting some of my code,kindly help me out to resolve this.
Sub Click(Source As Button)
Dim w As New notesuiworkspace
Dim ss As New NotesSession
Dim db1 As notesdatabase
Dim uidoc As notesuidocument
Dim thisdoc As notesdocument
Dim note As notesdocument
'Dim date1 As Variant
Dim datetime As New NotesDateTime( "" )
Dim efromD As New NotesDateTime( "" )
Dim etoD As New NotesDateTime( "" )
Dim excelNewWkbk As Variant
Dim xlRange As String
Dim Temp(30) As String
pth="E:\IS Help Desk Local Copy 13 dec2004\IS Help Desk Changed copy 13 dec 2004\IRequest-test.nsf"
Set db1=New NotesDatabase(srv,pth)
Set uidoc=w.CurrentDocument
Set udoc = uidoc.Document
Set thisdoc = uidoc.Document
Set view=db1.getview("Test")
n=3
c=2
a=1
Set collection=db1.getview("Profile")
Set doc1=collection.GetFirstDocument
Do While Not doc Is Nothing
	datetime.LSLocalTime=doc.logged(0)
	efromD.LSLocalTime=thisdoc.efromD(0)
	etoD.LSLocalTime=thisdoc.etoD(0)
	If  dateTime.DateOnly>=efromD.dateonly Then
		If  dateTime.DateOnly<=etoD.dateonly Then
				Array=doc.r_assignedto(0)'c is used for incrementing the rows values
				array1=doc.r_category(0)
				'Here in array in need to sort the data and also do not need the duplicate value
                                     Like"A,B,C,A,A,B,B------
                                     I need only "A,B,C
			Assigned=doc.r_assignedto(0)+doc.r_category(0)
			Set doc1=view.getdocumentbykey(Assigned)
			Set vc = view.GetAllEntriesByKey(Assigned)
			B=vc.count
	Set doc = view.getnextdocument(doc)
Loop
Subject: Urgent Help Reuired on LS Sorting and unique
I usually get the code from the Sort member list button in the Name and Address book, it sorts and gets rid of duplicates
Subject: RE: Urgent Help Reuired on LS Sorting and unique
but I need to store the value in the array in the while loop,and in that loop only i have to sort and remove the duplicate entries.and xtemp is no an array. FTemp=“@Unique(Xtemp)”
Means i am assigning the values on run time and then soring and removing the duplicates
http://searchdomino.techtarget.com/tipsSearchResults/1,289494,sid4,00.html?query=sort+and+array&type=tip&x=20&y=0
should help you out. You first have to be registered (for free)…
You also should have a look into the Version 4 and 5 forum.
Cheers,
Markus
