Hi All
I have written a JScript (.js) to approve deletion of replicated mail files.
The API ApproveReplicaDeletion() always fails with error “'Invalid Approval Request note.”
(I am also using the API for approving mail file deletion and that works fine with the similar script shown below.)
Am I doing anything wrong?
Heres the Jscript for Lotus Notes which I am running with its output, Any help is greatly appretiated:
I am running the script with the following command:
cscript.exe ApproveReplicaMailFileDeletion.js CN=tim46w2k3/O=pspl admin4.nsf passpass1
//Command line processing.
var args = WScript.Arguments;
if(args.length != 3)
WScript.Echo(“Invalid arguments to the Script - Usage: cscript.exe ApproveAdminPDeletions.js ”);
WScript.Quit(-1);
var serverName = args(0);
var adminPDBName = args(1);
var pwd = args(2);
//Create a Notes session.
var session = new ActiveXObject(“Lotus.NotesSession”);
session.initialize(pwd);
var dir = session.GetDbDirectory(serverName);
var admin4DB = dir.OpenDatabase(adminPDBName);
//Approve Replicated Mail File Deletion
WScript.Echo(“----------Approving Replica Mail File Deletion-----------”);
var ProxyActionForDeleteReplicaMailFile = “75”;
var dc1 = admin4DB.FTSearch("FIELD ProxyAction = " + ProxyActionForDeleteReplicaMailFile, 5000);
var docAd41 = dc1.GetFirstDocument();
while(docAd41 != null)
var sNoteID2 = docAd41.NoteID;
WScript.Echo("sNoteID2 " + sNoteID2);
try
var adminP = session.CreateAdministrationProcess(serverName);
var sNoteID22 = adminP.ApproveReplicaDeletion(sNoteID2);
catch(e)
WScript.Echo("Approval for Deletion of Replica Mail File FAILED - " + e.description);
docAd41 = dc1.GetNextDocument(docAd41);
OUTPUT
C:\Scripts>cscript.exe ApproveReplicaMailFileDeletion.js CN=tim46w2k3/O=pspl admin4.nsf passpass1
Microsoft (R) Windows Script Host Version 5.6
Copyright (C) Microsoft Corporation 1996-2001. All rights reserved.
sNoteID2 B3A
Approval for Deletion of Replica Mail File FAILED - Invalid Approval Request note.
C:\Scripts>
