Urgent for help on install domino 6.5 for RH AS 4.0
We have a compaq intel-based PC server running NT 4.0 with domino 5.0.5 on it, now , We plan to move them to another Xenon-based PC server with more memory and quicker CPU, I found Domino 6.5 for RHAS only support ver 2.1(It says it on CD label), but now, RH AS4.0 is already there, so is there another way to make RH AS 4.0 support Domino 6.5 (I have not contacted Lotus yet for upgrading the Domino 6.5 to the newest version). Any help would be greatly appreciated!
Yours
Kingofswing shen
Subject: urgent for help on install domino 6.5 for RH AS 4.0
What do you mean with another way? IBM has said it is not supported so you will have to convence them… As well is RH3 not supported because of different libraries on the Linux. This doesnt mean that you cant get it to run on RH4 but is it worth setting up a production server on an unsupported platform which there might be a large risk of problems? Will be like running a beta in production. No help to get from IBM if you need it.
//Kjeld
Subject: RE: urgent for help on install domino 6.5 for RH AS 4.0
Thanks,Larsen. you’re right,I just want to install an most up to date Linux OS for Domino, RHAS 2.1 maybe is a little bit earlier version than AS 4.0, It’s sure no good to put our main tasks on an unsupported platform :slight_smile:
Aslo please note that IBM state that Lotus Domino is supported on Red Hat Enterprise Linux version 3.0(AS/ES/WS)(check Web Site)Regards.
