Upgrade problem
I have the Domino server 7.0 installed on Windows XP. I even reinstalled it using the file C84W2na. I am trying to upgrade and tried the module C89vdna. I got the message "Installer found the incorrect 7.0 August 18 2005 …Looking in the install log It looks like most modules have the wrong checksum. The log says
“Lotus Domino (r) Server started, running Release 7.0”
Subject: Upgrade problem
Did you for any chances download it via ftp? Or Linux?
I mean, maybe you downloaded it into a Linux machine and then copied it to another PC via ftp.
Hi, You should,
  1. use killnotes.exe
  2. restart your computer
  3. uninstall the server via program.…
4.install the soft and follow the usual steps
Just let me know if you still have pbm. i’ll try to get around.
Bern’
Subject: RE: Upgrade problem
The killnotes.exe kills any running processes. I do not have a problem with that. My problem is that the C89vdna upgrade package does not recognize my installed 7.0 base (C84w2na) as the correct 7.0 version. The upgrade log lists a LONG list of wrong checksums. I do not see how the procedure you outline would help me with that
well we recently had a similar pbms. We solved one using the procedure i gave. We also solved another one checking the environment variables. The soft was looking for c:… . Hope this help. Bern’
Hi
Sometimes, of you make a FTP transaction with the flab binary set to 0, you will end up with a file which is different in size from the original.
I would download the file again
(I am assuming you are talking about the checksum on the installer and not in the already installed server)
Well, I used HTTP for download and the program did check the integrity of the install module OK. Eveything went smoothly until the installer (C89VDNA) checked the checksum of the installed 7.0 Domino modules, the installer definitely sees the installed version as the wrong one even if it is a 7.0 (C84W2na) (I just reinstalled it)
Like this ( a small sample):
File nservlet.dll failed checksum. (Found 0x54a27022, Expected 0x31901566)
File nupdate.exe failed checksum. (Found 0x8e9b0b92, Expected 0x39328280)
File nupdall.exe failed checksum. (Found 0xa205c97e, Expected 0x8b3bfbf6)
File LotusDomino.sym failed checksum. (Found 0x559e96d9, Expected 0x8f6ec00f)
File nwrdaemndll.dll failed checksum. (Found 0x13d66709, Expected 0x75845080)
File nxcgm.dll failed checksum. (Found 0xdf8540b2, Expected 0x701d1fc4)
File nxpcdmn.exe failed checksum. (Found 0x1f4eb0f0, Expected 0xd8e31fc8)
File nxtab.dll failed checksum. (Found 0x9897edff, Expected 0x584cb5f5)
File nxstr.dll failed checksum. (Found 0xf412889b, Expected 0x579e706d)
File nxtiff.dll failed checksum. (Found 0xc593caf, Expected 0x49c35190)
File gtr40nts.dll failed checksum. (Found 0x4062d008, Expected 0xf920193b)
Well, after you installed the server 7.0, did you started first? Or just run the upgrade program right after you installed it?
If you did not started if, try to do so and then run the upgrade program.
There must be something wrong with the original installation file for 7.0 even if everything seems OK. The install file is C84W2NA. It says 7.0 during installation.
I did a new install of the server using this file. Eveything worked OK, it says it installed 7.0. I did the install on a virgin computer that never have had a server installed on it. I did the setup and I run the server. Eveything worked fine. I closed the server and tried to upgrade using the upgrade found on the support site, C89WDNA. It still says that it found the wrong version 7.0 and refuses to update. It is very frustrating!
From the Domino log:
Domino log:
2007-10-30 12:49:21 Begin scan of databases to be consistency checked
2007-10-30 12:49:21 End scan of databases: 1 found
2007-10-30 12:49:21 Event Monitor started
2007-10-30 12:49:21 Event: Creating the Monitoring Configuration database.
2007-10-30 12:49:22 Creating Administration Requests database
2007-10-30 12:49:22 Lotus Domino (r) Server started, running Release 7.0
2007-10-30 12:49:22 Server started on physical node TRANSAM
From the install log
Using Notes program directory C:\PROGRAM\LOTUS\DOMINO
Using Notes data directory C:\PROGRAM\LOTUS\DOMINO\DATA
C:\PROGRAM\LOTUS\DOMINO\nstrings.dll
Identified Release 7.0.
File C:\PROGRAM\LOTUS\DOMINO\DATA\domino\java\actionbar.cab failed checksum. (Found 0x84b71db5, Expected 0xf355b246)
File C:\PROGRAM\LOTUS\DOMINO\DATA\domino\java\editor.cab failed checksum. (Found 0x31d83d56, Expected 0x6cfe58b5)
File C:\PROGRAM\LOTUS\DOMINO\DATA\domino\java\NCSO.jar failed checksum. (Found 0xf4cd830b, Expected 0xf9665f6e)
File C:\PROGRAM\LOTUS\DOMINO\DATA\domino\java\nvapplet.cab failed checksum. (Found 0x978a70dd, Expected 0x5b64badd)
File C:\PROGRAM\LOTUS\DOMINO\DATA\domino\java\outline.cab failed checksum. (Found 0x3e4281a7, Expected 0x9268ab9a)
File C:\PROGRAM\LOTUS\DOMINO\DATA\domino\java\domtags.jar failed checksum. (Found 0xf0633ea2, Expected 0xb2805582)
File C:\PROGRAM\LOTUS\DOMINO\DATA\domino\java\dominoapplets.cab failed checksum. (Found 0xc42ac9b, Expected 0x532e8f21)
File namgr.exe failed checksum. (Found 0x49e91ae6, Expected 0x9c37473c)
File namgrdll.dll failed checksum. (Found 0xca64c18, Expected 0x754cfdda)
File nca.exe failed checksum. (Found 0xde454fde, Expected 0x34ee7c7d)
File namhook.dll failed checksum. (Found 0x929ead04, Expected 0xf7acc840)
File ncompact.exe failed checksum. (Found 0xe2774b27, Expected 0x93644b5f)
File ndbnotes.dll failed checksum. (Found 0x5ec33aeb, Expected 0x3bf15faf)
File ndxli.dll failed checksum. (Found 0x77c87be5, Expected 0xd0e7c23e)
File ndomwsxmlcommon.dll failed checksum. (Found 0x41901b67, Expected 0x2baa1317)
File ndxlo.dll failed checksum. (Found 0xfcc79c4e, Expected 0xcdd493bb)
File nicppapi.dll failed checksum. (Found 0x1956698e, Expected 0xfb7613f7)
Yes. There must be something wrong with that install file. I have the one that comes with the jar file.
Try to unzip it using winrar or some sort of program like that. If you have any problems after that, then I would download it again.
Good luck
