UpdateProcessedDoc not working. ACL problem?
Hi designers,
UpdateProcessedDoc - do the signer/caller needs designer access or higher for this to work?
I have an agent, target “all new & modified documents”:
Set dc = db.UnprocessedDocuments
Set doc = dc.GetFirstDocument
While Not (doc Is Nothing)
Call doc.ComputeWithForm(True,False)
Call doc.Save(True,False)
Call session.UpdateProcessedDoc(doc)
Set doc = dc.GetNextDocument(doc)
Wend
This agent is called by agent.Run from another agent.
When I did this on my prototype, it works fine, only the new/modified docs are recomputed&saved.
But when I run it now on a second db (same data, same template), each call of the agent recomputes&saves all docs in the db!
The only difference between the 2 dbs are my access rights: In the second db I have only editor access (because this is the life/productive db).
thx in advance for any help
Uwe
