I have a web form that has a save button with the following code:
@Command([FileSave]);
@Command([FileCloseWindow]);
@Command([ToolsRunMacro];“UpdateEntry”);
I also have a WebQuerySave agent with the following:
@Command([ToolsRunMacro];“Release Document Lock”)
This lets me save the form the first time just great. However, when I go to edit the form on the web and then click the save button again, the changes are not saved. However, if I put this in the WebQuerySave:
it does save the edited form…but I can no longer create a form from scratch. Has anyone else run into this problem before? From the definition of the WebQuerySave method the @Command([FileSave]) should not work.
Thank you for your time.
