Undocumented TCP settings, IBM please help
In regards to my server performance problem
http://www-10.lotus.com/ldd/ndseforum.nsf/xpTopicThread.xsp?documentId=2C98A8A6601D58D88525818600376E80 http://www-10.lotus.com/ldd/ndseforum.nsf/xpTopicThread.xsp?documentId=2C98A8A6601D58D88525818600376E80
I found a solution as described here
Nevermind.dk http://nevermind.dk/nevermind/blog.nsf/subject/ibm-domino-a-very-annoying-performance-issue-now-solved
The server had TCPIP=TCP,0,15,0,45088, in notes.ini and detaching was very very slow. Changing this to TCPIP=TCP, 0, 15, 0,32800 detaching gets very fast.
Documentation for 32800 value:
http://www-01.ibm.com/support/docview.wss?uid=swg21164925 http://www-01.ibm.com/support/docview.wss?uid=swg21164925
This documentation only describes how to get 32800 value by combining encryption end compression.
But what are the other TCP port flags that gives the value 45088 ??
IBM please document what it is and why the value is used, thank you
(The value TCPIP=TCP,0,15,0,45088, is set by the Admin client when enabling encryption and compression I believe. )
Subject: Good deal, Mark, it’s plenty to get to the answer
These decimal numbers are actually binary flags.
450088 = 1011000000100000
Splitting em up yields:
x8000 + x2000 + x1000 + x20
… and your codes supply the definitions of each flag.
Subject: Not the answer - but found this add’l information
http://www.kalechi.com/doc/notesini.nsf/85255a87005060c585255a850068ca6f/8d0f57b937909eefc1256e9e0045eddb!OpenDocument http://www.kalechi.com/doc/notesini.nsf/85255a87005060c585255a850068ca6f/8d0f57b937909eefc1256e9e0045eddb!OpenDocument
Configuration for a TCPIP port.
Examples: TCPIP1=TCP,0,15,0,12288
TCPIP=TCP, 0, 15, 0 [,x] <----------- This is the setup for your TCP Port
…|…|…|… Application Data buffer size (0 is default which = 8000)
…|…|…Placeholder not used by TCP
…This is the port driver name
The last parameter x ([,x] above) can be decoded as follows:
0 X 8000 Encryption is enabled
0 X 0020 Compression is requested
0 X 4000 driver is internal
0 X 2000 no-op
0 X 1000 always for V2 and V3
0 X 0002 set to log modem I/O
0 X 0004 set to enable RTS/CTS
Selection NOTES.INI parameter
Nothing TCPIP=TCP,0,15,0,12288,
Compression only TCPIP=TCP,0,15,0,12320,
Encryption only TCPIP=TCP,0,15,0,45056,
Both TCPIP=TCP,0,15,0,45088,
