UNDER CITRIX XP = 2 problems > nds is running and editor access
I’m running citrix metaframe xp in windows 2000.i running lotus client 6.5 on…
i setuped policies on notes
when i log on pc (without citrix) everything is correct…
when i use ica client and open lotus i got errors…
  • sometime, this one : the signer of this notes must have editor access and the policycreator or policymodifier role to the domino directory.
  • sometine , that one : NSD is running, saving to file w:\notes\data\ibm_technical_support\nds_all_…the file maybe used by company’s helpdesk and ibm…
Do you have ideas ?
Eric
