Here we are facing problem that we are not able to close the uidoc.What will be the possible reasons for this one? I have put comments and system is not coming to post save even .Work only upto Query save.
Any Luck.
Any Luck.
Subject: Uidoc Problem
Maybe you have in the QueryClose event of the Form or in a embedded Subform the following code:
continue = false
Subject: RE: Uidoc Problem
Oh Yes …I do not know ,how can I skip this one?Thanks a lot Bern.
Just comment the line out with ’
in each event of a form or subform where has a parameter continue, you can set it to FALSE , then the event will not be executed. Default is allways TRUE.
regards bernhard
