Typical Problem
I have a text field in the form. In that field users enters values such as 1 2, 23 4 etc…when i save the document i want to see the fields to display without the spaces i have entered, in the above given example, the values should be 12 and 234…i want what ever space the user enters between the numbers to be removed. Can anyone help me on this.
Thanks in Advance
Subject: Typical Problem
Use @ReplaceSubString() to remove spaces from the value;
@ReplaceSubString(“1 2”:“23 4”;" “;”")
If You place @ReplaceSubstring in the Input Translation of the field, then it will prevent users from saving spaces in the field.
If You want them to be able to save the values with spaces, but You will only display it without spaces - then use the formula in a Computed For Display field (hidden in Edit mode).
hth
