hcl-bot
November 22, 2006, 8:25am
1
I have a view wherein i have 100 documents as of today. The first column of the view is the Names of employees. I have a form where in every document i have to show all the names of those employees. How can i do this. Can anyone help me on this.
Thanks in Advance.
hcl-bot
November 22, 2006, 8:35am
2
Subject: Typical Problem
You just want to list the 100 people on the view when you open the document (not as a picklist or anything?)
Then
@DbColumn (“”:“NoCache”;“”;“ViewName”;1);
If you want the values to be unique - add a @Unique ;
If you want to pull the data from another database change the value after NoCache (the “”) to the ServerName and Filename (Server:Filename).
If the data doesn’t change a lot you can remove the NoCache.
hcl-bot
November 22, 2006, 8:57am
3
Embed the Person view on the form.
Frunobulax
hcl-bot
November 22, 2006, 8:34am
4
You should use @DbColumn .
@DbColumn (“”:“NoCache”;cache;“”;“viewnamehere”;1)
