Type Mismatch Problem
SHowing the Type Mismatch for Forall
Set session = New notessession
set curdb = session.CurrentDatabase
Dim dbdir As New NotesDbDirectory(curdb.Server)
Dim db As NotesDatabase
Set db = dbdir.GetFirstDatabase(DATABASE)
While Not(db Is Nothing)
	Forall a In db.Agents
		Print a.Name
		If a.Trigger=1 Then
			Set ndoc = curdb.CreateDocument
			ndoc.form = "Second"
			ndoc.AgentName = a.Name
			ndoc.DataBaseName=db.Title
			ndoc.DataBaseTitle= db.FileName
			ndoc.DataBasePath = db.FilePath
			ndoc.AgentTrigger= "Scheduled Agent"
			Call ndoc.save(True,True)
	End Forall
	Set db = dbdir.GetNextDatabase
Wend
Subject: Type Mismatch Problem
Perhaps the db in question hasn’t got any agents so db.Agents isn’t an array.
Try:
If isArray(db.Agents) then
Forall a in db.Agents
HTH - Rufus.
