"Type Mismatch" Problem
Dear all,
I have written the script below in the QueryModeChange and it always pop out “Type Mismatch” error when I try to edit a document. Can anyone please help to check what’s wrong with the script. Thank you.
Dim ss As New NotesSession
Dim db As NotesDatabase
Dim uidoc As NotesUIDocument
Dim accessrole As Boolean
Set db = ss.CurrentDatabase
Const role = “@IsNotMember(@Name([Abbreviate]; @UserName); Createby : Participant)”
accessrole = Evaluate(role)
If accessrole = True Then
    Messagebox "You are not authorised to edit this document !"
    Continue = False
    Exit Sub
Else
    Continue = True
Subject: RE: “Type Mismatch” Problem
Declare role as string data type and try.
Subject: “Type Mismatch” Problem
Evaluate always returns a variant, so you have to access the role as “If accessrole(0) then” or you can try imploding accessrole and read it as a string
  • Sudhir
