Found what appears to be a bug in the travel verse application on iPhone 6 plus and 6 with IOS 9.1 installed. Sound notification is turned on for the Verse app but no sound when new mail is received. I’m also pretty sure the vibrate function is not working either.
And I did check all the sound notification settings are set to ON.
The pop message indicator does come up but not very handy when the phone is out of sight. Anybody else experiencing this issue?
Subject: engineering response on PMR for this issue
Created a PMR (65540,442,000) as I thought this was some kind of bug but apparently not. Can’t seem to find any logic about sound notification not being included from the developer statement. What were they thinking??? Hopefully fix will arrive soon.
The development team returned with the update:
“IBM Verse does not support sounds on notifications. The settings for audio, banners, etc are generic settings for any application that can receive notifications but does not indicate that the application necessarily supports them. The only notifications you will get from verse are banners. The Audio Alerts setting is only used for calendar events that have alarms. This setting has nothing to do with remote notifications from the server.”
I see that the latest DEV update on this case is as follows (date stamp 2015/11/02)
“The Verse app on iOS does not currently support sounds when new messages
are received. We are considering whether to implement such a feature in
the future, but currently it is not planned. This would be an
enhancement request.”
We could suggest opening a pmr with us and having an engineer add your additional interest onto the existing associated enhancement request spr to add weight on it’s interest of being supplied as a feature in a new/upgraded release.
