Traveler and sender
I have a couple of issues reported in regards to traveler.
  1. A user opens a new email. Closes it. It then appears that the user sent the original mail. (ie user A emails user B. User B reads it - closes it - the mail then looks like User B sent it). This is on the traveler side and the Notes client (Doc properties show the sent by fields have been changed to User B. Intermittent - happened twice - different users.
I cant see anything in the traveler log or the server logs.
I have re-installed the files on the MDA. ran FIXUP / UPDALL on the mail files. I cannot see any rules or agents in the mail files that could be blamed.
Any one got any ideas?
Subject: RE: traveler and sender
The Traveler team has seen something similar to this and is investigating the issue.
Subject: at least
I know its not just me then :0)
I have logged this with support.
Subject: Solution???
We also noticed this behavior a few times in combination with traveler.Is there already a solution for?
Subject: Fixed with version 8.0.1.2
We had the same problem and found that this had been fixed with version 8.0.1.2 for the Traveler client.
