Traveler 8.5.2.1 Problem (Waiting for Connection)
Firstly, thanks to the team for releasing Traveler 8.5.2.1 ahead of 2011. Unfortunately, we are encountering a serious issue with the installation on Android devices. If the native browser is used, a “Waiting for Connection” is received and the download never completes. The following technote mentions that it will not work with self-signed certificates. We are using 3rd-party certificates. The technote needs to be updated.
http://www-10.lotus.com/ldd/dominowiki.nsf/dx/Android_troubleshooting_LNT8521
According to some recent postings on this forum, there is a hotfix (L057088) to address issues when 3rd-party certificates are used. It seems to be certain certificates and not all. There is no issue with our setup as it has been working 100% for months. Where can we secure this hotfix? Thanks in advance.
***We have successfully installed on several Android devices in our environment and know about the work-arounds (use another browser…) but this is unacceptable for production deployment.
Subject: Re: Traveler 8.5.2.1 Problem (Waiting for Connection)
Here is the tech note about the problem that is fixed via LO5788, which has a link to download the fix.
http://www-01.ibm.com/support/docview.wss?uid=swg21458224&myns=swglotus&mynp=OCSSYRPW&mync=E
