Total in column width reader field
HelloI have a view column witch display the total of column value.
The documents have reader field so a user cannot see all documents of the database.
the total culumn don’t to take into account the reader field : the total is the total of all documents instead of the total of the documents that the user can read.
Is it a lotus bug ?
Subject: total in column width reader field
No, it’s working as designed. The index isn’t created by the user, but by the server, and the index is where the totals live. If you want user-specific totals with no other information available, you need user-specific (private) views. Since the index is created with the user’s permissions, the index cannot contain values from documents the user cannot see.
