This seems really basic, but I can’t seem to find a good solution in Notes help or in forum searches.
I have a document open on the web in edit mode. I am trying to program a simple “discard changes” button that takes me back to read mode for the current document.
@Command([EditDocument]; 0) won’t work because the parameters are ignored on the web.
@Command([OpenDocument]) seems to re-open the document, but in edit mode again (also tried this with a “zero” parameter - no luck).
Trying:
@Command([OpenView]; “LookupView”; “”);
Now this should work, however I keep getting an “entry not found in index” error, despite the fact that I know the UNID value is listed in the first column of the view, which is sorted. Grr!
Do I have to go to Javascript to manipulate the location.href directly? I hate using Javascript to do something that Notes will do natively.
I’m looking for a simple way to return to read mode or some suggestions on what to look for on the “entry not found in index” problem with OpenView->OpenDocument.
Thanks all!
