Hi friendz, I have a requirement which states that if value is entered in the field(notes client) , it should be entered from right to left(As in calculator).Usually it will be from left to right.Is there any way to accomplish this.
Thanx in Advance
Regards,
Thish.
Subject: To enter text from right to left
If this is for Hebrew, then I’d check with the appropriate language sets. If this is for a calculation or one-off field, then I guess your only option is to use SendKeys so that on every keydown you move to the left instead of to the right. It doesn’t feel like a good, robust solution, but I can’t think of anything else that would do it.
regards,
raphael
Subject: RE: To enter text from right to left
Hi Raphael, Thanx for ur suggestion…
Regards,
Thish.
I’m not sure if this is what you are after: Open the field properties sheet, click on the Paragraph alignment tab (sixth tab from the left) and select Right-to-left reading order.
