I want to enable TAPI call in lotus notes. I found one lotus script for Make Call, which invokes the phone dialer for making the TAPI call
The lotus script for TAPI make call is follows:
Declare Sub tapiRequestMakeCall Lib “TAPI32” (Byval lpszDestAddress$,Byval
lpszAppName$, Byval lpszCalledParty$, Byval lpszComment$)
Sub Initialize
Dim s As New NotesSession
Dim doc As NotesDocument
Dim strPhoneNumber As String
Dim strAppName As String
Dim strCallParty As String
Dim strComment As String
Dim docTmp As NotesDocument
Set doc=s.CurrentDatabase.UnprocessedDocuments.GetFirstdocument
If Not doc Is Nothing Then
strPhoneNumber=doc.OfficePhoneNumber(0)
If strPhoneNumber=“” Then strPhoneNumber=doc.PhoneNumber(0)
If strPhoneNumber=“” Then strPhoneNumber=doc.phone_number(0)
strAppName=“Notes Dialer”
strComment=“Automatic Dialing”
strCallParty=doc.FullName(0)
Set docTmp= s.CurrentDatabase.CreateDocument
docTmp.CallParty=strCallParty
If ws.DialogBox ( “Notes Dialer”, True, True, False, False, False, False,
“Notes Dialer”,docTmp) Then
strPhoneNumber=docTmp.PhoneNumber(0)
strCallParty=docTmp.CallParty(0)
If Instr(strPhoneNumber," x") Then
strPhoneNumber=Left$(strPhoneNumber,Instr(strPhoneNumber, " x")-1)
If strCallParty=“” Then strCallParty=doc.orgName(0)
If Trim(strPhoneNumber) <>“” Then Call
tapiRequestMakeCall(strPhoneNumber,strAppName,strCallParty,strComment)
I want to add a menu item something like “Call” or “Make Call” or “Make TAPI Call” or “Place Call”, when I right click on a contact in Lotus Notes Contacts. And upon selecting the menu item it should call the lotus script shown above(which does the actual TAPI Call - invoking Phone Dialer).
How Can I do this? I have installed Lotus Domino Designer in my machine. Please Help…
