hcl-bot
1
So we’ve created a button to add a location document to the users client into their names.nsf.
I’ve got everything set except I’m having a problem with the doc.disabledports = “” part.
here’s the code:
doc.DisabledPorts = “SPX”
the problem is I want to disable the LAN0 and COM1 ports as well, what is the syntax for doing this? I’ve added multiple lines like this:
doc.DisabledPorts = “LAN0”
doc.DisabledPorts = “COM1”
except it will only disable the last one, the first two will stay enabled.
I’ve tried it this way as well:
doc.DisabledPorts = “SPX, COM1, LAN0”
and
doc.DisabledPorts = “SPX;COM1;LAN0”
and even
doc.DisabledPorts = “SPX” ; “COM1” ; “LAN0”
Still no dice.
What am I missing?
hcl-bot
2
Subject: RE: Syntax in Lotus Script - HELP!
Hi John, try this:
Dim disPorts(0 to 2) as string
disPorts(0) = “SPX”
disPorts(1) = “LAN0”
disPorts(2) = “COM1”
doc.DisabledPorts = disPorts
I think this should work.
Emily.
hcl-bot
3
Thanks! Those worked great!
Subject: Syntax in Lotus Script - HELP!
for all those wich use for a solution:
“How to Modify Which Client Ports Are Enabled With LotusScript”
http://www-1.ibm.com/support/docview.wss?id=swg21145214
Bye
Dominik
hcl-bot
5
John,
I always do it this way
Dim port_array(2) as string
port_array(0)=“SPX”
port_array(1)=“LAN0”
port_array(2)=“COM1”
doc.DisabledPorts = port_array()
HTH
Mike
