Here is an example of a multivalue text field I have on my form. Entries are separated by a new line:
Labor>><<5/9/05>><><<222>><<50
Material>><<5/9/05>><><<224>><<52343
Material>><<6/1/05>><><<3523>><<3482
Labor>><<7/1/05>><><<5248>><<300
The information is displayed in Computed for Display text fields in a table using @Word.
Using the data above, I need to sum the last two columns in my table. What would be the best way to get the information into a list I can use? @Implode or @Explode or both?
