Suggestion: Need LotusScript method for "NotesRichTextItem.AppendHotSpot"
A LotusScript NotesRichTextItem method is needed for a “AppendHotSpot”. Currently, API exist for AppendText, AppendDocLink, and many other items, but not for appending a HotSpot that points to a URL.
Use case: Creating a complex document via LotusScript that contains dozens, hundreds or even thousands of URL links to web based resources. For example, the following table was created via LotusScript. The first two columns should be URL links that point to the live data for these records. Since the URLs are very long, it is impractical and confusing to simply provide the full URL into the document. In other words, the usage needs to be very similar to an HTML anchor i.e. text where only the text is visible.
Universal ID
CMVC ID
State
Severity
Age
Platform
Subsystem
Component
ReportedRelease
Track
Releasename
Fix Potential
Headline
Projected Date
Owner
Dept
FW123456
987655
Working
2
172
project1_all
abc
ccmm
eFW3.4
approve
abc340
F341R
abstract text 1
2008-12-02
user1@us.ibm.com
XYZ1
FW234567
098765
Working
2
2
project2_all
abc
ccmm
eFW3.4
approve
abc340
F341R
abstract text 2
2008-12-02
user2@us.ibm.com
XYZ1
Subject: Suggestion: Need LotusScript method for “NotesRichTextItem.AppendHotSpot” (ok… that did not work)
I tried using the Notes Toolkit… but this only updates a new notes item. Does anyone know how to modify this in the context of BodyRichTextItem.BeginInsert(BodyRichTextNavigator) and EndInsert within an existing Body rich text item?
This only creates a new item.
Dim memPtr As Long
Dim memLen As Long
Dim memhandle As Long
Const TYPE_HTML = 21
Const ITEM_SIGN = &H0001
Declare Function NSFItemAppend Lib “nnotes” (Byval noteHandle As Long, Byval iFlags As Integer,Byval iName As Lmbcs String,_
Byval iNameLength As Integer, Byval iType As Integer, Byval iValuePointer As Long, Byval iValueLength As Long) As Integer
Declare Function OSMemAlloc Lib “nnotes” (Byval T As Integer, Byval S As Long, hM As Long) As Integer
Declare Function OSMemFree Lib “nnotes” (Byval hM As Long) As Integer
Declare Function OSLockObject Lib “nnotes” (Byval H As Long) As Long
Declare Sub OSUnlockObject Lib “nnotes” (Byval H As Long)
Declare Sub Poke Lib “kernel32” Alias “RtlMoveMemory” (Byval P As Long, Byval D As Lmbcs String, Byval N As Long)
Sub Initialize
  Dim s As New notessession
Dim db As notesdatabase
Dim doc As notesdocument
Dim html As String
Dim itemname As String
Dim memPtr As Long
Dim memLen As Long
Dim rc As Integer
Set db = s.currentdatabase
Set doc = db.createdocument
doc.form = "Memo"
doc.Subject = "Email with URL Hotspot"
Dim recipients( 1 To 2) As String
recipients( 1 ) = "user1@us.ibm.com"
recipients( 2 ) = "user2@us.ibm.com"
itemname = "Body"
html = |<a href="http://server.domain.com/cgi-bin7/defectview?entity=691480">691480</a>|
memLen = Len(html)
rc = OSMemAlloc( 0, memLen, memHandle)
memPtr = OSLockObject(memHandle)
Poke memPtr, html, memLen
rc = NSFItemAppend( doc.handle, ITEM_SIGN , itemname, Len(itemname), TYPE_HTML, memPtr, memLen)
OSUnlockObject memHandle
OSMemFree memHandle
Call doc.send(False, recipients)
Subject: Help!!! Suggestion: Need LotusScript method for “NotesRichTextItem.AppendHotSpot”
I am still looking for a solution to this challenge. I have tried a couple of solutions, but none scale to large tables, and none of the solutions I have tried work with BodyRichTextItem.BeginInsert(BodyRichTextNavigator).
Any and all suggestions welcome!!! Thanks in advance for any guidance.
