Subscript out of range when completing more than 1 recipint in CopyTo
I have an editable field (INaddcopy) in a form with type “Names”. Next to it is a button with this formula:
FIELD INaddCopy := @Name([CN];@PickList([Name]:[Shared]));“”
So, the user can select 1 or more names out of the Company’s Name & Address book.
Then, there is a “Submit” button in which an email is sent to the persons in the field INaddcopy:
This script is used:
Dim maildoc As NotesDocument
Dim rtitem As NotesRichTextItem
Dim strPersonName As String
Dim nn As NotesName
Dim recip(5) As String
Set maildoc=New NotesDocument(db)
maildoc.SendTo=doc.INsupv(0)
maildoc.copyTo=doc.INdivmgr(0)
recip(0) = doc.INaddCopy(0)
recip(1) = doc.INaddCopy(1)
maildoc.BlindCopyto = recip
maildoc.Subject = "First notification Injury - " + doc.INNum(0)
Set nn = ss.CreateName(doc.INsupv(0))
strPersonName = nn.Common
Set rtitem = New NotesRichTextItem( mailDoc, “Body” )
'Call rtitem.AppendText("Dear " + doc.INsupv(0) + “,” )
… ETCETERA …
maildoc.Send(0)
The problem is probably in the instruction:
… where I’m getting a “subscript out of range” error
What am I doing wrong?
Subject: subscript out of range when completing more than 1 recipint in CopyTo
If zero or 1 additional copy intos are specified then you cannot refer to doc.InAddCopy(1).
Note that doc.InAddCopy(0) will be valid as set to “” if no copy intos are selected.
Additionally, why is recip being declared as a fixed size array?
If you need to use recip, declare it as a variant.
Dim recip as variant
recip = doc.INAddCopy
mailDoc.BlindCopyTo = recip
If this is the only purpose of recip, skip it and use
mailDoc.BlindCopyTo = doc.INAddCopy
Subject: RE: subscript out of range when completing more than 1 recipint in CopyTo
Hi Andrew,The problem is that when more than 1 addressees are selected in the doc.INaddCopy, the mail is not sent. When there’s only 1 person there’s no problem.
Before I changed to the array thing, my code was this:
maildoc.BlindCopyTo=doc.INaddCopy(0)
Also when I left out the (0) it didn’t work.
Check your InAddCopy variable. Is it marked as allowing multi-values?
Also check your existing document to see what the value of InAddCopy is stores as via Right-click, Document properties.
