Subform problem
Anyone who can help me with regards to subform…
How can i view my created subform if i put it to an outline entry? What formula should i use?
Your help will be very much appreciated.
Thank you.
ML
Subject: Subform problem
A subform is designed to be located on a (parent) form, so you will have to create a form with your subform.
When there is nothing else define on that form, nobody will notice this.
Subject: RE: Subform problem
Hi Rob,
Thanks for replying so fast. Actually i already have the main form where the subform is located. What am i trying to do is to access the subform which i created for administration purposes. I wanted it to be viewable by the admin so they will be able to access/edit it when they want to update the attachment that is stored in the subform. I had to think of putting it into an outline so it will be viewable in the main page. I don’t know if that would be possible.
Thank you.
