Subform not visible on web. (Domino 6.51 upgrade issue)
EnvironmentServer Domino 6.51
Web Client (IE 5.5)
I’m currently performing some app testing for an upcoming 5.12 to 6.51 domino server upgrade. I’ve found a strange problem where a form (with subform) that displays correctly in the browser using domino 5.12 does not appear fully when served by 6.51. The problem appears to be that 6.51 simply doesn’t render the subform and the form appear but without the subform components visible.
The identical apps work ok on 5.12 - can Lotus make a suggestion as to what could cause this behaivour. Are there known issues with subforms in 6.51 if so please let me know what these are.
(N.B. I’ve checked hide-when and they are fine)
Subject: Subform not visible on web. (Domino 6.51 upgrade issue)
After some investigation this problem is related to a new feature in R6 subforms. The subforms must all be marked with the available for public access flag via R6 designer and then are rendered successfully be Domino.
