I need to open a Image in Stream. I was able to do it when the image is located in my c drive as well on the network but how do i refer to the same image when it is in database as imageResource or fileResource
you can have the design elements show in a view. I can’t remeber the trick off hand (it has to do with the $Flags field), but this then gives you the possibility of accessing design elements as Notes documents, therefore passing them to the Stream.
