I’m trying to upgrade from 6.5.x to 7.0.1. When SmartUpgrade launches, it successfully unpacks the attached installation kit (full install kit), Notes shuts down, I see the “Upgrading Notes…” dialog box and then I get the error dialog “Error applying transforms. Verify that the specified transform paths are valid.” The upgrade fails.
This is strange since I am not using a transform file. However, we did use a transform file during the last upgrade to install Notes 6.5.1. Has anyone else encountered this problem or have any ideas on how to correct?
Here is my SmartUpgrade package config:
Kit description: Windows: 6.5.* → 7.0.1
Enable this kit for use: Enabled
This Smart Upgrade kit can be used to update the following versions of Lotus Notes:
Source versions: Release 6.5.{12345}
Operating system: Windows/32
Localization: English
Release 6.5.4/6.0.5 or previous? Yes
After applying this kit, the client will be running this version of Lotus Notes:
Destination version: Release 7.0.1
Restart Notes after update: Restart
Location of update kit:
Attach update kit here: c88rcna.exe
Optional arguments for attached kit: /s /v"/qb+!"
Thanks in advance,
Bill
