Strange results when using GetAllEntriesbyKey and Getalldocumentsbykey
Hi,I have a program which will compare the total amount of all documents by key,I tried using GetAllEntriesbykey and Getalldocumentsbykey, but the result are different. The total amount is equal for using getalldocumentsbykey, but is not equal when I am using Getallentriesbykey, I also using messagebox to display the result, they are actually are equal. but how come the result is different for the two Notes objects?
Thanks a lot for any help.
  1. this is the codes using Getalldocumentsbykey:
Dim db As notesdatabase
Dim view As notesview
Dim viewEntry As notesviewentry
Dim doc As notesdocument
Dim totalCR As Double
Dim totalDR As Double
Dim viewEntryColl As notesviewentrycollection
Dim selectedInvoiceFolderNV As notesview
Set view = db.GetView( "JVLineDisplay" )
Set viewEntryColl = view.GetAllEntriesByKey("CB000983")
totalCR = Cdbl(0)
totalDR = Cdbl(0)
Set viewEntry = viewEntryColl.getfirstentry
While Not viewEntry Is Nothing
	Set doc = viewEntry.document
	If Instr(doc.JV_DBCR(0), "Credit") Then
		totalCR = totalCR + doc.jamount(0)
	Else
		totalDR = totalDR + doc.jamount(0)
	Set viewEntry = viewEntryColl.getnextentry(viewEntry)
Wend
If totalDR = totalCR Then
	Messagebox "They are equal"
	Messagebox "totalCR:" + Cstr(totalCR) + "totalDR:" + Cstr(totalDR)
Else
	Messagebox "they are not equal"
	Messagebox "totalCR:" + Cstr(totalCR) + "totalDR:" +Cstr(totalDR)
Subject: I M not sure
Cause I haven’t got designer open with the help.
But I think it could be a problem of index cause I think that the entries work like a collection…
But I don’t use them often and I m not sur about it.
Subject: RE: I M not sure
Thanks a lot for all of your help.I have tried to set the TotalDR and TotalCR to zero, it is still not working.
The reason is that the codes which using the ViewEntrycollection are running on the production now, and it works for a long time, but today we found only case it is not working, I debug the codes and creating a agent to test it, I found the getalldocumentsbykey is working for this case,we can not replace it only for this case, probably it is not working for other cases. I must figure out why.
Anyway, thanks a lot for your help.
Subject: Difference between Entry and Document
A major difference appeare when you use multi-valued fields.
IN THEORY…if you create a view where th first column is based on a multi-valued date fields and set this column to show each value in a specifique row. A GetAllDocumentByKey order where key is a date, will return all document.
A GetAllEntriesByKey will return only row according to the date passed as argument.
IN THEORY… Because this is not working everytime as expected.
Subject: strange results when using GetAllEntriesbyKey and Getalldocumentsbykey
you may want to try to first set totalCR and totalDR equal to 0, or maybe that step is just missing from above.
ex:
Dim totalCR as Cdbl(0)
Dim totalDR as Cdbl(0)
totalCR = 0
totalDR = 0
Then do the WhileNot
Just a quick question: If you have a method that works, (getalldocsbyKey), then why not just run with it and forget the other method? Just curious
