We have upgraded a 5.0.10 Domino server running on an IBM x440 server to R6.0 and after upgrade the Server Build Number on the server document remains same on R 5.0.10,Can some one help me on this problem …little urgent…thanks in advance…
Subject: Strange problems with R6 upgrade
The build number will change sometime in the next few days. Look at your Administration Requests database and you will see a request to do this pending.
You can probably force it to run with a “Tell adminp process all” command at the console, but it is probably better to let the system do things in it’s own order and time.
Stephen Lister
The adminp wil change it for you, but if the server cannot find the server himself (?) then it wil not be changed.Check if you have the correct settings in the server document:
Ports - Notes network ports. Take a look at the Network address… is this correct ???
You can however change this in the IP address of the server…
