Strange problem with the Categorized View
I got a strange experienceI have a view in which first column is Categorized.documents under that category should be sorted.I have field Pdocid(suppose) should containg the first document Unique id.That should be for all All documents.
This is the Sample code iM sending
dim View as NotesView
Dim vc As NotesViewEntryCollection
Dim firstEntry as NotesEntry
Dim SecondEntry as NotesEntry
View is Set
Vc is set
If Vc.Count <> 0 Then
Set FirstEntry = Vc.GetFristEntry
FirstEntry.document.Pdocid = FirstEntry.DocUniqueId
End if
If Vc.count > 1 then
for i = 2 to Vc.count
FirstEntry = Vc.GetNthEntry(i-1)
SecondEnrty = Vc.GetnThentry(i)
If FirtEntry.Document.certNo = SecondEntry.document.CertNo Then (CertNo is the Filed That is Categerized)
SecondEntry.Document.Pdocid = Firstentry.document.Pdocid
Call SecondEntry.Document.save(True,False)
Else
SecondEntry.document.Pdocid = SecondEntry.document.DocUniqueId
call SecondEntry.Document.Save(True,false)
Next
end if
The problem is The code is Working Absolutely fine wen im Debugging line by line and it is happening inthe Application .But its is Not Happening wen im running the script in Run Mode.
Can any one help me inthis regard will be highly appreciated
My personal id is ravidaparthi@yahoo.com
Subject: RE: Strange problem with the Categorized View
Use Option Declare.
If that doesn’t solve your problem, please be more specific about what your code is doing wrong and what you would like it to do. Also, please post your actual code – copy and paste rather than retyping it. The code you have posted contains several syntax errors and other problems, and would obviously not run without errors whether or not you were in the debugger.
I don’t believe that this code is doing anything different when you debug it, but if so, we need details.
