Strange problem with response documents
The user is working on a main document, editing it, and create a response document. Fill the response document, save it and close it (this response doc, update some values on the main document).
After all, the user close the main document (with out saving it), but when he tries to open it (main doc), some problems appears:
hide_field (field with hide formula): “value”
Section A: hide_field
Section B: ! hide_field
But…(!) when the above example occurs, and the main document is open for reading, the section “A” and section “B” are showing! (not when the main document is being editting).
Somebody knows, the reasons, and how can be possible fix it ?
Thanks!
