Strange LotusScript Loop Issue
I have a strange issue with the loop below. The loop is creating records in our database for every other record is reads from the iSeries. In other words we are getting records 1, 3, 5, 7, 9 etc. written to the Notes Db but we should be getting 1,2,3,4,5,6,7,8,9 etc. I’m sure it is something simple that I am just not seeing. Any help would be appreciated
If Not con.ConnectTo(dataSource, userName, password) Then
	LogAction("Could not connect to P1EMPLY from Training.nsf" )
	result.Close(DB_CLOSE)
	con.Disconnect
	Exit Sub																				' added end if  jmo 3/26/02
Else
	Set qry.Connection = con
	qry.SQL = "SELECT * FROM QS36F.P1EMPLY WHERE P1CLK >= '15342' ORDER BY P1CLK"
	Set result.Query = qry
	result.CacheLimit = DB_ALL
	result.FetchBatchSize = 1000
	result.Execute
	If result.IsResultSetAvailable Then
		Do
			result.NextRow
			'try to locate matching employee number in Training Db
			ee = Cstr(result.GetValue("P1CLK"))
			Set doc = EmpTrainTblView.GetDocumentByKey(Cstr(result.GetValue("P1CLK")), True )
			If (doc Is Nothing) Then
				'Adding record for Hourly employee in training db
				NumberNewPeople = NumberNewPeople + 1
				Set newpersondoc = New NotesDocument(db)
				newpersondoc.Form = "Person"
				newpersondoc.EmployeeNum = Cstr(result.GetValue("P1CLK"))
				newpersondoc.JobID = "0000-0"
				newpersondoc.New = "New"
				Call newpersondoc.ComputeWithForm( False, False )
				Call newpersondoc.Save(True,False)
				Set emaildoc = New NotesDocument( db )
				emaildoc.Form = "Memo"
				emaildoc.Subject = "New hourly employee #" & Cstr(result.GetValue("P1CLK")) & " " & newpersondoc.FirstName(0) & " " & newpersondoc.MiddleName(0) & " " & newpersondoc.LastName(0)
				Set rtitem = New NotesRichTextItem( emaildoc , "Body" )
				Call rtitem.AppendText("New Employee: #" & Cstr(result.GetValue("P1CLK")))
				Call rtitem.AppendText( " " & newpersondoc.FirstName(0) & " " & newpersondoc.MiddleName(0) & " " & newpersondoc.LastName(0) )
				Call rtitem.AddNewLine( 1 )
				Call rtitem.AppendText("Click Here to Open ")
				Call rtitem.AppendDocLink( newpersondoc, "Click Here to Open")
				Call emaildoc.Send(True, MailTo)
			Else ' Employee Numbers Matched
'Update doc in training db: Active Status
				If result.GetValue("P1TRMC") = "D"  And doc.NonActiveEmployee(0) <> "Inactive" Then
					Call SetRecordsToBeActiveOrInactive(doc,"Inactive",NumOfDocsModified)
'Changed to Inactive"
					DeActivatedPersonCount = DeActivatedPersonCount + 1
				If  result.GetValue("P1TRMC") <> "D" And doc.NonActiveEmployee(0) <> "Active" Then
					Call SetRecordsToBeActiveOrInactive(doc,"Active",NumOfDocsModified)
'Changed to Active
					ReActivatedPersonCount = ReActivatedPersonCount + 1
					emaildoc.Subject = "Reactivated hourly employee #" & Cstr(result.GetValue("P1CLK")) & " " & doc.FirstName(0) & " " & doc.MiddleName(0) & " " & doc.LastName(0)
'Reactivated record for Hourly employee in training db
					Call rtitem.AppendText("Reactivated Employee: #" & Cstr(result.GetValue("P1CLK")))
					Call rtitem.AppendText( " " & doc.FirstName(0) & " " & doc.MiddleName(0) & " " & doc.LastName(0) )
					Call rtitem.AppendDocLink( doc, "Click Here to Open")
		Loop Until result.IsEndOfData
		con.Disconnect
