Strange Email Problem
Hi.
One of our users has a problem with certain Inbound internet emails.
An external person (Fred@msoft.com) will send an email to say Joe Bloggs/Acme (joe.bloggs@acme.com), along with several others in the office.
This one user will receive the email as :
To: Joe Bloggs
Send by: Fred@msoft.com
The other users will receive the From as: Fred@msoft.com, which is the correct sender.
This scenario only happens on certain external emails.
Can anyone suggest what is causing this ?
Thanks,
Simon
Subject: check the message mime source
view → show → page source
and if you can recreate, maybe try and trap the message at the router
(open mail.box when router task is temporarily turned off)
and compare the routed page source with the trapped message’s
You may find that the message is arriving corrupt
Subject: Re Message Mime Source
Hi Brandon.
Thanks for the reply. The messages in question are often sent to several internal recipients.
Only the 1 user receives the emails with the incorrect sender. All other users receive the emails correctly.
I was just wondering if there was a setting on the client that may be causing this, as all users are using the same
mail template.
Subject: Update
I have asked IBM and they say it is a Traveler based issue that is fixed in Traveler 9.0.1 IF5
Subject: Same issue here too
Hi guys,
We are having the exact same issue.
Has anyone come up with a solution to this problem?
Thanks in advance.
Subject: Doc properties, Fields
Check the From field in doc properties to see if it contains the sender’s address and that the SMTPOriginator field is that same.
If they are correct, then I’d replace the design of the mail template on the user’s mailfile. If you’ve got Designer, check out the design beforehand to see if the Memo Form has been changed or corrupted.
