Strange calendar behaviour - help? #2
This is the same problem described by Paul Pennington on 09/04/2008 and left without answer :
Just upgraded a Notes client from 7.something to 8.0.1. When he opens his calendar, instead of event descriptions, he gets a number which I’m pretty sure corresponds to the event type (meeting, appointment, reminder, etc). When he opens the event (dbl click) everything looks normal. When creating an event, same thing - it creates ok, but doesn’t display the description , it displays the single digit number.
Any help will be appreciated.
Jean-Pierre Bloch
Subject: [Solution] : Agenda shows numbers instead of descriptions
Sometimes you get funny ideas :
Well, I decided that, beacuse the $Meeting view was wrong, I just could delete it.
After a design replace, everything went well back.
I hope that this will help some other guys.
Jean-Pierre
